  • Skip to primary sidebar
TheWindowsClub Logo
List of freeware tools and other releases from The Windows Club
This page list all the Freeware, Tools, eBook, Themes, Screensavers, Wallpaper, and other releases from The Windows Club. Maybe you have landed here out of choice, or maybe you clicked on a direct zip link on another website and ended up here! Scroll down to see what interests you. We are that sure you will find something of value here!
BEFORE YOU DOWNLOAD: Click here to scan Windows for issues causing speed loss
TheWindowsClub Icon
FixWin 11 is the best PC Repair software or Windows repair tool! It has been updated to version 11 and is optimized to support Windows 11 and Windows 10 operating systems.
Ultimate Windows Tweaker 5 for Windows 11 is one of the best tweaking software.
FixWin 10 for Windows 10 is a portable freeware that allows you to fix and repair Windows 10 problems, issues, and annoyances.
Ultimate Windows Tweaker 4 for Windows 10, apart from offering you the usual tweaks, lets you tweak Privacy settings and more.
10AppsManager will let you easily uninstall and reinstall Windows Store apps in Windows 10.
AltPlusTab lets you customize the AltTab menu in Windows.
Hide Taskbar lets you hide only the taskbar, and not the Start Button, with a click. Simply download and run the app. Use hotkeys Ctrl+Esc  to hide or un-hide the taskbar.
Thumbnail and Icon Cache Rebuilder for Windows 11/10 will purge, clear and delete your Thumbnail and Icon Cache Rebuilder in a click.
Windows Logon Notifier lets you create user logon messages for Windows 11/10/8/7 users easily.
Ultimate Windows Tweaker 3 for Windows 8 and Windows 8.1 is just 340 KB in size and includes over 170 tweaks.
Ultimate Windows Tweaker 2.2 is a freeware TweakUI Utility for tweaking and optimizing Windows 7  & Windows Vista, 32-bit & 64-bit.
FixWin v1 for Windows 7 is a 529 KB freeware portable application to repair & fix common Windows  and Windows Vista annoyances & issues
FixWin v2 for Windows 8 is a free portable application to repair & fix common Windows annoyances & issues in Windows 8, and Windows 8.1.
Ultimate Windows Customizer lets you customize Windows Explorer, Context Menus, Libraries, Logon Screen, Start Orb, Taskbar, Windows Media Player and many areas of Windows 7 and Windows 8.
Fix WMP Utility is a portable app that re-registers all the concerned Windows Media files required for the smooth functioning of Windows Media Player.
Fix WU Utility will re-register the files required for the proper functioning of Windows Updates. This utility will re-register a total of 114 files which are required for the proper functioning of Windows Updates.
Windows Themes Installer is a freeware portable utility that allows you to patch system files, install a theme, remove a theme, and restore defaults easily in Windows 7 & Vista.
Right-Click Extender for Windows is a freeware utility that allows you to add some important items to the right-click context menu. It allows you to add or remove many additional options to a Drive, File, Folder, Computer and Desktop’s Right Click Context Menu.
Prevent stops Cut, Stops Paste, Stops Copy, Stops Delete, Stops Copy To, Stops Move to, Stops Send To,  Prevents renaming, Disables Task Manager’s End Process button. It also grays out the context menu items, disables Ctrl+C, Ctrl+X, and Ctrl+V and/or stops the process.
Windows Access Panel is meant to minimize your trouble in accessing certain programs in Windows.
Handy Shortcuts will help you create the oft-used desktop shortcuts for your Windows desktops easily: Lock WorkStation, Switch Account. Shutdown, Restart, Log Off, Hibernate, Show Desktop, Uninstall Programs, Device Manager, Security Center, Windows Defender, Windows DVD maker, etc.
Windows Program Blocker is a free App or Application blocker software to block software from running on Windows.
ScreenOff is a 13KB freeware that lets you turn off your Windows laptop monitor screen manually on-demand in a click, without putting it to Sleep.
The Windows Feeds Gadget displays the RSS Feeds of The Windows Blog and The Windows Club. Stay abreast of what’s happening in the world of Windows!
CleanDesktop is a small portable freeware app that will help you clean up your unused desktop icons in Windows 8, Windows 7 & Vista. This utility is for those who miss the XP’s wizard.
I’M A PC Themepack and Wallpapers for Windows 7 and Windows 8.
The Complete Windows 7 Shortcuts eBook includes a lot of new keyboard shortcuts that are unknown to a new user. This eBook comprises more than 200 keyboard shortcuts containing almost all the keyboard shortcuts that are available in Windows 7 and its default programs.
Windows 7 for Beginners eBook covers topics that would typically interest a novice wanting to start using Windows 7 or a beginner trying to get his hands wet on Windows 7.
Quick Restore Maker is a smart 1-click freeware app for creating a System Restore Point in Windows 11/10 and Windows 8/7.
GodMode Creator is a freeware utility that lets you create 38 “GodModes” in Windows 11/10/8/7.
SMART (Service Management And RealEasy Tweaking) Utility for Windows 7 is a freeware utility which helps you tweak Windows 7 Services, based on the suggested configurations of BlackVipers.
Context Menu Editor for Windows is a freeware tweaking utility to add/delete application shortcuts, Win 32 commands, files, and website URLs to your desktop and folder context menu.
Quick Clean for Windows is a freeware tool that lets you clean up the junk files from your Windows desktop quickly.
Taskbar Thumbnail Tweaker & Resizer for Windows 7 makes Taskbar Previews appear faster or increase taskbar thumbnail preview size easily!
Windows 7 Taskbar Thumbnail Customizer allows you to resize & tweak the Windows 7 taskbar thumbnails left & right, in & out! You can change the size of the thumbnail, its spacing, top, bottom, left, right margins and mouse delay time too!
File Association Fixer v2 for Windows 11/10/8/7 can easily help you fix, repair and restore the broken file associations.
File Association Fixer lets you fix file type associations easily, with a click! To fix the association for a particular file type simply click on the file type association icon or name. These pages contain file association fixes for some of the most common file types. Currently, the app offers 18 fixes for Windows 7 & 26 fixes for Windows Vista.
READ: Fortect Repair Tool Review.
Disguise Folders is a free tool that lets you camouflage your secret folders and allows you to disguise them as system folders in Windows.
HotShut is a free tiny app that lets you do something very simple. It lets you shut down, restart, lock or log off your Windows computer instantly from your taskbar notification area.
Winter White Windows 7 Theme, includes a screensaver, cursor set, and wintry wallpapers.
Windows 7 Start Button Changer allows you to change the Windows 7 Start Orb or Button easily. The program will backup your original explorer, change the start button and restart explorer. To restore the default Start Orb and explorer from the backup, click Restore Original Explorer Backup.
OneWorld Theme For Windows 7 changes the Task Pane & the Welcome Center too and is thus a ‘first of its kind‘ theme for Windows 7. We may think we are different … of different nationalities … of different color or cultures, but every once in a while, we need to be gently reminded that we are ONE … and ALONE in the Universe.
Royale Blue Theme For Windows Vista is a theme you may want to check out!  Those of you who miss the Royale Blue XP Theme may want to try this Royale Vista theme.
Windows 7 Regional ThemePack for Asia takes you on a journey in Asia. Visit countries from Japan to Taiwan, from Thailand to India, China to Hong Kong and Malaysia. See if you can recognize the 12 sights. Enjoy the change every hour, every day!
Windows 7 DreamScene Activator is a small freeware portable app that will allow you to activate DreamScene in Windows 7 too! Those of you who missed the DreamScene feature of Windows Vista  Ultimate, in Windows 7, can now add it easily to Windows 7 and Windows 8.
Windows 7 Folder Background Changer is a freeware portable application that allows you to change the folder backgrounds in Windows 7. You can also change the color of the text and show shadows under the text and even apply the same background to all the subfolders!
Fix IE Utility re-registers all the concerned system files required for the smooth operation of Internet Explorer.
Fix MSE Utility is a portable utility that will reset all the Registry and other settings of Microsoft Security  Essentials to their default value. This utility will restore all its registry values & service settings to known good defaults without re-installing MSE. It also re-registers the concerned system files required to run MSE properly.
QRM Plus Manager lets you create restore points, carry out system restore operations & selectively delete system restore points in your Windows computer. You can also add these options to your right-click context menu.
System Restore Manager is a freeware portable utility that allows you to completely manage your Windows system restore points and customize its options. Using this utility, you can even select a Drive and change the maximum amount of disk space to use, System Restore can use, change the System Restore Point Creation Interval, etc.
Read: Restoro review.
Start My Day is a first of its kind freeware process launcher for Windows users. Simply put, Start My Day is for those users who hate going through the same process each day, loading this and that.
Create A Shortcut adds the ability for a user, to select where to create a shortcut for a file system object, from anywhere on a user’s computer.
Sliced Themepack & Wallpaper set for Windows 7 comprises of 7 beautiful abstract wallpapers. Various colors have come together to play with black to bring out a mysterious glazed glass look.
Icon Cache Rebuilder repairs and rebuild a corrupt icon cache in Windows easily in a click.
IE 9 Tweaker, which lets you tweak some select settings of Internet Explorer 9 easily. The main feature of IE9 Tweaker is the ability to create your own customized Homepage similar to IE9  About:Tabs page. You can also make IE9 show more rows in the about:tabs page. Please also see IE9 Tweaker Plus.
HomePage Maker, is a freeware portable app that allows you to customize your Internet Explorer, Firefox, Chrome & Opera browser home page.
Windows Event Viewer Plus is a portable freeware app that lets you view Event Logs faster than the default in-built Windows Event Viewer and also export the Entry to a text file, select the Web Search Button to look up the entry online, to find out more information or troubleshoot errors.
WP7 MarketPlace Enabler allows you to access the MarketPlace from anywhere in the world via your Zune software.
The Ultimate Guide to Speech Recognition in Windows 7 explains everything about a superb feature of Windows 7 which is called ‘Speech Recognition’. Speech Recognition is a technology that is used for controlling computers using some voice commands and that too, very accurately.
Windows 8 Clock Logon Screensaver for Windows 7 has been inspired by Microsoft’s next version of the Windows operating system.
IE9 Tweaker Plus allows you to tweak, customize and change over 27 settings in Internet Explorer 9 RTM, all from one single window.
C# Tips, Tricks for Beginners eBook will help you learn the basics of C sharp programming, tips, tricks tutorials the easy way.
RegOwnit allows you to take ownership of a Windows Registry key using Administrator, Home Users or the current Logged On User account.
AeroTile is a freeware portable app that adds glassy backgrounds to system folders and places them on your Windows desktop to give you ready access to these folders.
Ease Of Access Replacer replaces Ease of Access button on Windows 7 or Windows 8 Logon Screen with buttons to take out Lock Screen and Logon Screen Screenshot, CMD, Powershell, Registry Editor, Run and Task Manager.
System Folders Customizer lets you add Internet Explorer, important System folders, Control Panel applets to your Computer folder, Libraries and Desktop.
Right Click Restart Explorer is a simple tool that adds Restart Explorer to your right-click context menu.
QuickHide hides taskbar processes, programs, and applications quickly. And why would you want to do that? Maybe you are doing something you shouldn’t be doing and your dad or Boss comes in … QuickHide could be a lifesaver – by letting you hide all in a click!
RightClick ReplaceThis allows you to replace files in Windows 7 easily. It is also helpful in cases where Windows will not allow you to replace files that are being used.
Show Desktop Remover is a freeware tool that lets you easily remove and restore the Show Desktop button appearing on the right side of the Windows 7 taskbar.
Taskbar Shadow is a small tool that adds a cool drop shadow effect to the Windows 7 taskbar. It creates a shadow for the taskbar in any position – bottom, top, right or left!
Taskbar Color Effects lets you add Color, Background and Shadow Effects to the Windows 7 Taskbar.
PinToStartMenu adds the ‘Pin to start menu’ item to the context menu of folders and the Control Panel applets and lets you pin Control Panel items and folders to Windows Start Menu, via your right-click context menu.
MailMyFile lets you mail your files to your preferred mail ID, directly quickly, and from your right-click context menu.
Web Pinner is a freeware app that can add website links to your Windows 7 desktop’s right-click context menu quickly and easily.
The Ultimate Laptop Buyers Guide. Planning to buy a new laptop but don’t know which laptop to buy, with so options out there? Unsure if you need a business-style laptop or a personal laptop for your home needs? If so, then this Laptop Guide from The Geeks Club is something you definitely want to read.
The Ultimate Tablet PC Buyers Guide. This 40MB guide from The Geeks Club consists of 49 pages that will guide you through your decision to buy a Tablet PC.
Metro UI Tweaker for Windows 8 is a freeware tool, designed to allow you to tweak Metro UI settings in Windows 8.
Start Button ToolTip Text Changer will allow you to change the tooltip text of your Start Button or Orb in Windows 7. Feel free to replace the default text ‘Start‘, with any text of your choice, in the text box. You can replace it with your name or simply choose something witty.
WLM Blocked Sender Tool lets you manage Blocked Senders List in Windows Live Mail. Add, Remove address, export, save, import blocked senders list in Windows Live Mail easily.
Autorun Deleter is a free program that disables and deletes the Autorun.inf virus. If you find that a removable media is infected with the autorun.inf virus, simply run this tool. It will delete the file and make a change in the Windows registry to ensure that it does not appear again.
Balloon Tip Time Changer is a simple tool that lets you customize and set your own time for the balloon tips or Windows notifications to stay open in your taskbar notification area.
Ribbon Icons Customizer will let you change the icons on the Windows 8 explorer. It lets you change even its default icons, with a click.
InstaMailer will allow you to quickly send an email to any email ID using your Hotmail and Gmail accounts. This software will be especially useful in situations where you need to quickly send out mail to someone, and you don’t want to go through the process of opening the web interface or your default mail client.
WinMailer is a stand-alone freeware, that will allow you to quickly send an email, along with attachments, to anyone using your Hotmail, Gmail, Yahoo, AOL or any other email account, right from your Windows desktop.
Start Orb Mover will allow you to move the Start Button and the Start Menu to either the center of the Taskbar or far right\bottom, depending on Taskbar location.
Windows 8 Aero Lite Tweaker lets you enable the Aero Lite Glass theme in Windows 8.
WiFi Profile Manager 8 is a simple tool to view your Preferred Wireless Network Profiles in Windows 8. This tool tries to replace the functionality of the Wi-Fi Preferred Network dialog box of Windows 7.
Modern Tile Maker for Windows 8 will allow you to create Modern or Metro style Tiles for Files, Folders, Desktop Programs, Web links and more. The tiles actually appear like a Metro UI tile – similar to how the Metro apps tiles look.
Windows Screen Capture Tool will allow you to capture full screen, selected screen area, windows, web pages and more. You can also add watermarks to your captured screenshot or edit the image using its basic image editor.
PassBox is a handy little tool that will remember all your passwords. It can even suggest or generate strong passwords for your account.
Tile Locker prevents users from pinning, unpinning, rearranging Tiles on Windows 8 Start Screen.
Windows Tile Color Changer is freeware for Windows 10/8.1/8 allows you to change the color of pinned Tiles of your desktop apps, on your Start Screen.
I hope you like our releases!
Primary Sidebar
  • X
  • RSS
  • Add as a preferred source on Google
  • YouTube
  • Connect
Latest News
October 23, 2026
Meta Muse is coming to Windows 11 using MXC Integration
October 7, 2026
Latest Reviews
October 23, 2026
October 22, 2026
Explee Review: AI lead generation and outreach platform
