IE Tweaker, a Power Toy for tweaking Internet Explorer.
IE Tweaker is a freeware app, released by my friend Raghu who runs IETips.net, a website dedicated to all things Internet Explorer. This app will help you to tweak Internet Explorer & has over 90 tweaks and fixes for Internet Explorer.
IE Tweaker packs in the following:
- A total of 90 “PowerToys” tweaks & fixes.
- Quickly Enable/Disable Tabs under IE Internet Options.
- Easy to repair options and fixes
- Enable/Disable various options
- Create Quick Shortcuts
While IE Tweaker has been tested on IE 8 & IE 7, it may work on earlier versions of Internet Explorer too, provided the corresponding feature set is available.
Always good to create a system restore point before making any changes to your system.
Related posts:
Recent posts:
Popular posts:
Comments
Did it have a (Paste And Go) option
only for that I’ll download it.
No it doesn’t, but perhaps http://www.winvistaclub.com/g30.html may interest you.
Leave a Comment
