We widely use speed test software to check our internet connection speed, using tools like speed test, speakeasy, etc. When it comes to LAN, hard drive or USB drive speed tests, there is no better tool then LAN Speed Test. LAN Speed Test is a simple yet powerful tool to check LAN connection speed and hard drive read-write speeds.
LAN Speed Test for Windows 11/10
To begin with the program there should be at least two computers in the same network, as it is required to run the test to get the exact numbers of packet data sent and received by the program. Once it is confirmed that you have at least 2 computers in the network, go ahead download and run LAN Speed Test.
After the installation is complete, users will be greeted with program T&C, when the application is executed for the first time. On the second screen of the program, it will ask to browse for the folder, where it will save the log files.
Measure Local Area Network speed
LAN Speed Test then asks the user to select the amount of data that is needed to transfer, to check the speed in Megabits, Megabytes, Kilobytes and Gigabytes format. Megabytes is the default size used to measure the speed connection. The number of data packets that are sent to check the speed is 100 MB (default), but this can be defined by the user, based on their requirements.
Once all the settings in LAN Speed Test are adjusted and verified according to the requirement, then push the “START TEST” button to run the test and get the result. The time duration to complete the test lasts less than a minute.
Features of LAN Speed Test
- Easy and portable to use -runs test in just a few seconds
- Small installation file (182KB) and can be executed from hard drive, USB drive, etc.
- Very fast, more tests can be executed in less than 1 minute
- Offers log viewing screen wherein one can see speed test logs
- Open and save option in .CSV file format
- Customizable speed measurement
- Command-line mode feature allows network administrators to start the test from the client’s workstation and view the automatically generated file anywhere.
There are already many speed testing tools available in the market but LAN Speed Test gives the exact result on a home network connection. The usefulness of such a tool helps users to identify, diagnose the data packet when it comes to stream contents over the network.
LAN Speed Test application is available for free download and is compatible even with Windows 11/10.
You can download it from its home page.
