Are you encountering error code 8018 on the Dead by Daylight game? Here is a full guide to help you fix Dead by Daylight error code 8018 on your Windows PC and Xbox console. Dead By Daylight (DBD) is an online survival horror asymmetric multiplayer game which is getting more popular day by day. Millions of gaming enthusiasts love it. But like any other game or service, it is not without errors. There are some errors and issues that players keep experiencing time and again. One such error reported by DBD players is the Connection Error with error code 8018. When triggered, you will see the following error message:
CONNECTION ERROR</
Cannot connect to online services. Please try again later.
Error code: 8018
Now, this error could be a result of multiple scenarios. It might occur because of a server problem or connectivity issues. If you are one of the affected users who keeps getting error 8018 in Dead by Daylight, this post is for you. In this guide, we will show you potential fixes to resolve the error at hand.
What causes Error Code 8018 on Dead by Daylight?
The error code 8018 on Dead by Daylight may occur due to different reasons for individuals. Here are some potential causes:
- It might be caused if the Dead by Daylight servers are facing technical issues at their end. Make sure the game servers are up and running.
- One of the common causes of this error is an internet connectivity issue. If your internet connection is not stable, you are most likely to encounter error code 8018 on Dead by Daylight. Try optimizing your internet connection, then check whether the error is gone.
- Your overprotective security suite might be blocking the connection between Dead by Daylight and the game servers. So, you can try allowing the game through your firewall and antivirus to fix the error.
- In a few cases, the error might be caused if the game launcher is missing administrator permissions to run the game. Hence, you can try relaunching Steam or Epic Games Launcher with admin rights to fix the error.
These scenarios are most likely to cause error code 8018 in Dead by Daylight. In any case, you can try the fixes mentioned above to remove the error.
Fix Dead by Daylight CONNECTION ERROR CODE 8018 on PC and Xbox
Here are the solutions that you can try to fix the error code 8018 on your Windows PC or Xbox console:
- Reboot your PC or console.
- Make sure the servers are not down.
- Relaunch Steam or Epic Games Launcher as an administrator.
- Ensure that you are connected to a stable internet connection.
- Power cycle your router/ modem.
- Whitelist the game through your firewall or antivirus.
1] Reboot your PC or console
First, try restarting your PC or Xbox console to fix the error. It could be a temporary system glitch causing Connection Error 8018 in Dead by Daylight. Hence, a simple restart might work to resolve the error.
However, if the error still pops up after rebooting your device, there may be an underlying issue triggering it. So, you can move on to the next potential fix to resolve it.
2] Make sure the servers are not down
This Connection Error with error code 8018 in Dead by Daylight could be caused by an ongoing server issue. Such errors usually occur if the game servers are facing a technical difficulty, like a server outage issue, and there is a widespread issue. It might also be the case that the game servers are currently under maintenance and thus are unavailable at the moment. So, before trying any other fix, it is recommended to check the current server status of Dead by Daylight and make sure the game servers are up and running.
There are multiple online free server-status detector tools that you can use to check whether or not the Dead by Daylight game servers are down. You can open a website like DownDetector.com, IsItDownRightNow.com, or Expert-Exchange.com in your web browser and then check the current server status of Dead by Daylight. There are other ways to check that, too. For example, you can go to the official pages of Dead by Daylight on Twitter, Facebook, or some other social media. They mostly post updates regarding the current server status. If the servers are down, they will notify you on their respective page.
For the users who are experiencing this error on their Xbox console, try checking the current service status of Xbox Live. If Xbox services are unavailable, you might get the error at hand. So, verify the current status of Xbox Live services and ensure all the services are available and running.
In case there is indeed an ongoing server issue, you will have to wait until error 8018 on Dead by Daylight is resolved by the server team. Meanwhile, try relaunching the game a few times to see if the error is gone.
However, in case the game servers are online and available and you still get the same error, there must be some other factor causing the error. In that case, try the next potential solution to fix the error.
3] Relaunch Steam or Epic Games Launcher as an administrator
The next thing you can do is run your game launcher i.e., Steam or Epic Games Launcher with administrator privileges. Missing administrator rights and required permissions to run the game launcher might cause problems in establishing a connection between the game servers and Dead by Daylight. This might cause error 8018 in the game. Hence, you can try resolving the error by relaunching your game launcher as an administrator.
If you use Steam, launch it as an administrator, then try opening Dead by Daylight. In case you use Epic Games Launcher to play the game, run it as an administrator and then try playing the game. Here’s how you can do that:
- First of all, close your Steam or Epic Games Launcher app and make sure no related process is running in the background. You can use Task Manager to end related tasks.
- Next, go to Steam or Epic Games Launcher’s shortcut icon on your desktop and press the right-click on it.
- Now, from the appeared context menu, tap on the Properties option.
- In the newly opened Properties window, just go to the Compatibility tab.
- After that, tick the checkbox called Run this program as an administrator and click on the Apply > OK button to save changes.
- Finally, relaunch Steam or Epic Games Launcher and open the game to check if the error is resolved now.
If this method doesn’t help you fix the error at hand, you can try some other fix to get rid of it.
See: Dead by Daylight keeps Crashing or Freezing on PC.
4] Ensure that you are connected to a stable internet connection
Such connection errors are generally caused by a weak internet connection. Online multiplayer games like Dead by Daylight require an active and reliable internet connection. If your internet connection is unstable, it will hinder your gaming experience as you are likely to encounter connection issues. So, make sure you are connected to a stable internet connection suitable for online gaming.
You can follow some tips and tricks to optimize your internet connection:
- Try testing your internet speed and make sure it is good for playing online games smoothly. Else, you will be required to upgrade your internet plan to play Dead by Daylight without any hindrance.
- If there are any, resolve WiFi problems and then check whether the error is gone or not.
- You can try connecting to a different WiFi or network to see if the error is resolved.
- Make sure your network drivers are up-to-date as outdated and faulty drivers can cause connection problems.
- You can use a wired connection instead of a wireless one and then check if the error is fixed. A wired connection is more reliable for online gaming than a wireless network.
Now, if you have tried all the above tricks and the error is still the same, you can move on to the next potential fix to resolve the error.
5] Power cycle your router/ modem
If the above solutions didn’t work for you, you can try performing a power cycle on your networking device which is a router or modem. Some connection problems are triggered due to an issue with your router or old and bulked-up router cache. Hence, if the scenario is applicable, power cycling your router should help you fix the error at hand.
You can try using the below simple steps for performing a power cycle on your router/ modem:
- First of all, press the power button present on your router to switch it off.
- Now, unplug the power cord of your router from the main switch.
- After that, wait for at least 30 seconds to let the device switch off completely.
- Next, plug in your router again and turn it on.
- When you have switched on your router, reconnect to the internet and launch Dead by Daylight to check whether the error is resolved or not.
If the error persists, here are a few more fixes you can try.
Read: Fix New World Connection Errors on Windows.
6] Whitelist the game through your firewall or antivirus
In many cases, these connection errors are caused by interference from your firewall or antivirus. Your security suite might be preventing the game client from establishing a successful connection to the game servers. As a result, error 8018 is triggered. To check whether your firewall or antivirus is causing the problem, temporarily disable it. If it is, try whitelisting Dead by Daylight in your firewall or antivirus.
Here are the steps to allow Dead by Daylight through Windows Firewall on Windows PC:
- First, open the Windows Security app by clicking on the taskbar search option and searching for it.
- Now, go to Firewall & network protection and click on the Allow an app through firewall option.
- Next, click on the Change settings button and allow Dead by Daylight on both Private and Public networks.
- In case you don’t find the Dead by Daylight game in the list, you can press the Allow another app > Browse and select the Dead by Daylight executable file. You are likely to find the game at the following locations:
C: > Program Files (x86) > Steam > steamapps > common
C:\Program Files\Epic Games - After adding the game, allow it on both Private and Public networks.
- Finally, try reopening the game and check if the error 1808 is fixed or not.
Similarly, you can try adding the game to your antivirus’s exclusion/Whitelist/Exception list to fix the error.
That’s it.
How do I fix error 8001 Dead by Daylight?
To fix the error code 8001 on Dead by Daylight, first of all, make sure that the game servers are not down. Also, test your internet connection and make sure it is optimized. If youare seeing this error on your Xbox console, try power-cycling your console or clearing the cache to fix it.
How do I fix error code 8012 DBD?
If you are experiencing the error code 8012 on Dead by Daylight, you can try fixing it by checking the current server status and ensuring the DBD servers are not down. Also, make sure your internet connection is stable and optimized. You can also try power-cycling your device, flushing the DNS cache, or repairing Easy AntiCheat.
Now read: Fix Epic Games connection error, issues, and problems on Windows.
