StrokeIt is an advanced mouse gesture recognition engine and a command processor that allows you to perform various daily functions such as minimizing windows, controlling web browser, etc, more conveniently.
StrokeIt – Mouse gesture software for Windows
The program comes preloaded with more than 80 unique mouse gestures and drawing instructions and does not require any additional files or libraries for its installation.
Mouse gestures are simple symbols that you “draw” on your screen using your mouse. When you perform a mouse gesture that StrokeIt can recognize, it will perform the action associated with that gesture.
The installer is around 140K and recognition engine weighs approximately 15K. Once installed and run, the programs icon stays in the notification area for ready access to any of it settings.
The application can be disabled anytime by holding down the Control key, or by placing cursor over the StrokeIt icon in the system tray and doing a right-click. Likewise, any mouse gesture can be cancelled by simply doing the left-click.
StrokeIt is available in 2 versions:
- Home: Characteristics are already mentioned in the above description.
- Pro: The newer version endorses some extra features in an attempt to appeal business and power users.
StrokeIt Home is absolutely free for personal use and you can download it from here.
Works on Windows 8, Windows 7, Windows Vista and Windows XP.
