If you use your Windows PC extensively, especially if you are a true gamer, you will know the value of a liquid cooler for your system. Liquid coolers help maintain the integrity of the hard drive, CPU, and GPU. The only reason people sometimes hesitate to go for a water cooler is the issue of possible leakage. You need a safe, durable all-in-one liquid cooler for the CPU.
Best CPU coolers for gaming PCs
Here are the 10 most reliable CPU liquid coolers for Windows 10 systems:
- Cooler Master Hyper H410R Cooler
- Cooler Master MasterLiquid ML240L
- Corsair Hydro CW-9060028-WW
- Cooler Master MasterLiquid Lite 120
- Cooler Master MasterBox Lite 5
- Cooler Master MasterLiquid ML240R
- CHIPTRONEX Diffuser X500 RGB CPU Cooler
- DeepCool CPU Liquid Cooler Captain 120 EX
- Cooler Master V8 GTS
- Antec Kühler H2O K Series K240.
Let us take a look at them.
1] Cooler Master Hyper Hyper 212
The Hyper Hyper 212 Cooler from Cooler Master is one of the most popular products of this trusted brand. You can get yourself a solid water cooler that you can rely on to keep your PC safe and running at its best. The model weighs less than 700 grams and comes with a thermal paste. Buy it on Amazon and enjoy a 2-year warranty.
2] Cooler Master MasterLiquid ML240L
If you want to make sure your PC does not make annoying noises, go for a cooler that comes with a low noise guarantee. This cooler will do it. It lets the performance make the noise, only figuratively. It comes with a customized, low resistance radiator and a dual chamber RGB pump for quick and efficient cooling. The product weighs 1.14kg, but the air balance fans and FEP tubing make it worth it. So go get it on Amazon today.
3] Corsair Hydro Series H45
Buy this easy-to-install device for your Windows 10 system at Amazon. The advanced fan design of this model gives better air delivery at a high-static pressure while the 120mm radiator covers a large area for cooling. The best thing about this model is the cold plate and pump designed for high performance with low noise.
4] Cooler Master MasterLiquid Lite 120
Here is yet another all-in-one water cooler from Cooler Master. If you have been looking for an easy-to-install, low-noise water cooler for your Windows 10 device, buy this one from Amazon. The dual dissipation pump, thick FEP tubing, and 120mm Air Balance fan design make this product the perfect all-rounder.
5] Cooler Master MasterBox Lite 5
Here is another great option for you from Amazon. If performance and looks are both equally important to you, this is the model you want to go for. This stylish model comes with 3 RGB fans, a tempered glass side panel, and a dark mirror front panel. You get efficient cooling with 4 120mm fans to ensure undisturbed performance from this model.
6] Cooler Master MasterLiquid ML240R
Well, it mentions almost all the best the features along with the name. But there’s more. This model is on Amazon because of the range it allows. The wired Addressable RGB controller makes this model compatible with RGB and non-RGB motherboards. This product is compatible with almost every PC that is running Windows 10.
7] NZXT Kraken X62
The NZXT Kraken X62 isn’t all about aesthetics. The amazing design couples with high performance. The device, its speed, and liquid temperature could be monitored either using a Desktop app or a mobile app. The reinforced tubing adds to the warranty of the product, thus pushing it to 6 years. You could buy the NZXT Kraken X62 water cooler from Amazon here.
8] DeepCool CPU Liquid Cooler Captain 120 EX
This high-density water cooler comes with a self-governed circulation system that makes it one of the most efficient models as far as heat dissipation is concerned. This water cooler for Windows 10 is available on Amazon. You can check out the beautiful glass design. The unique thing about this model is the patented external circulation system. If you are all about the safety, go for this model because it comes with an upgraded rubber tube designed to be anti-explosion. This model is probably the most durable one on the list due to it’s corrosion-resistant, crush-resistant, and thermo-stable properties. Even with all these features and hardware detail, this product weighs less than 1kg. This one is my favorite one on the list.
9] Cooler Master V8 GTS
This high-performance cooler comes with a horizontal vapor chamber to minimize CPU hotspots. The cooling system comes with eight heat pipes to enable even cooling. The 3-tower heat sink helps dissipate the heat within seconds so that you can keep gaming without worrying about your hardware for even a second. Buy this beautiful product on Amazon for the best dustproof and durable cooler experience.
10] Antec Kühler H2O K Series K240
Extremely powerful is exactly what this water cooler is. It is available on Amazon. Check it out. It comes with an aluminum radiator, the blue LED on the PWM fan that has Silence mode and Battle mode. This is a very good buy if you are trying to protect your CPU and GPU from the impact of all the heavy-duty gaming you put your PC through.
These are all good options; what you need to focus on is the features part. Go for the one that has all the features you need. Be its low noise, or quick cooling, or self-cleaning. Whatever it is, do go in with a generous budget because the best ones aren’t the cheapest. Consider this an investment to protect your PC and increase its longevity despite heavy usage.
