Weekened Giveaway: 10 licenses of Revo Uninstaller Pro
Continuing in our tradition of giving you a quality shareware for free every so often, this weekend, we are thankful to Revo Uninstaller for offering us 10 licenses of their Revo Uninstaller Pro!
revo uninstaller pro Weekened Giveaway: 10 licenses of Revo Uninstaller Pro
Revo Uninstaller Pro helps you to uninstall software and remove unwanted programs installed on your computer easily! Even if you have problems uninstalling and cannot uninstall them from your control panel applet.
With its advanced and fast algorithms, Revo Uninstaller analyzes an application’s data before uninstall and scans for remnants after the uninstall of a program.
After the program’s regular uninstaller runs, you can remove additional unnecessary files, folders and registry keys that are usually left over on your computer.
To remove a program completely and without leaving a trace you can trace & monitor all system changes made during its installation, and then use that information to uninstall it with one click only – simple and easy!
Revo Uninstaller gives you another 8 handy and powerful tools to clean up your system – AutoRun Manager, Windows Tools Manager, Junk Files Cleaner, Browsers History Cleaner, Office History Cleaner, Windows History Cleaner, Unrecoverable Delete Tool, and Evidence Remover.
Visit its HomePage for more!
While Revo Uninstaller also has a free version, feature-rich Revo Uninstaller Pro cost $39.25; but 10 licenses are being made available FREE to the readers of The Windows Club!
To win a license simply download its free or trial version and let us know here in the Comments section, one of its feature that you like the most. 10 lucky winners will be selected randomly and the serials mailed to them, by me. The giveway will be kept open for 4 days starting now. And yes … the first one to put in a proper request here will definitely get a license!
Feel inclined to connect with us and stay in touch ?  You can Follow us on Twitter, Connect with us on Facebook or Subscribe to our RSS Feeds. smile Weekened Giveaway: 10 licenses of Revo Uninstaller Pro
Thanks optimus!
If you have liked this post, you might want to check out some more, on topics like , .
About AnandK@TWC
Anand aka HappyAndyK is an end-user Windows enthusiast, a Microsoft MVP in Windows Desktop Experience since 2007, and the Admin of TheWindowsClub.com, TheGeeksClub.com & WinVistaClub.com. Creating a System Restore Point before trying out a new software or a tweak is always recommended.
Ads
Random Posts
  • Nic
    Hi – I’ve been using Revo Uninstaller Free version for some time and it’s fantastic. Looks Like the Pro version is similar to my other Favourite, Total Uninstaller. My favourite feature is that it can run portable. I run it from Liberkey on my USB drive. Would love to win Pro version pls.
  • Panayotis
    Revo is my Favorite Uninstaller.
    I use the Free version.
    I hope I win the Pro.
    Please, count me in!
    Thank you!!!
  • Michael
    Thanks for your great giveaways.
    I like this software because of the efficient cleaning and its easy appliance.
    Please count me in.
    Best regards
  • MerleOne
    Hi all,
    I definitely like this software. The Pro feature I like most is the monitoring of installation, making it possible to fully uninstall trial software.
    Thanks for counting me in.
  • Kevin Talley
    Hello! Biggest feature in PRO version is the installation monitor feature — hands down! It’s great to be able to see exactly what an install touched in the registry. Thanks for the giveaway!
  • Ryan
    The feature I like best about Revo Uninstaller Free is that it automatically creates a system restore point before proceeding with the uninstallation of a program and removal of redundant registry entries and files left-over by the built-in uninstaller. This saves me time and headache if in any case the uninstallation goes wrong (so far, it hasn’t). To add to that, the AutoRun Manager is useful for me to quickly remove unnecessary startup items (as compared to usng msconfig)) and the Windows Tools is a great easy all-under-one place for me to access and launch the standard useful Windows programs which are other-wise scattered on the Start Menu.
    I had also previously tried the trial version of Revo Uninstaller Pro and was impressed with the other added features especially the real-time monitoring of program installation (create a log of it so that it may be used to completely remove the program later on in the future if the need arises). Unfortunately the trial lasted only for days and I had to revert back to the Free version. As such, I truly hope I can win a license key for the Pro version in this giveaway. (I tend to try out and experiment with tons of apps on my real machine, not on a VM, as such Revo Uninstaller Pro is something that I truly need for a long-term use)
    Once again, thanks for having this giveaway.
  • John
    Thanks, I like the ability to trace & monitor all system changes made during its installation, and then use that information to uninstall it.
  • Shankar
    Revo Free is a good program. Pro version not tried. Thanks for including me.
  • Jim Wade
    Been using free version for long time….best free
    application I have ever seen….reliable, fast, and most of all, very easy to use.
  • Abhishek
    The best feature of Revo Uninstaller is its unique ability to clean the leftover files and registry entries plus its hunting mode.
    Thanks for the giveaway.
  • james madigan
    Revo removes more registry keys and files unlike other programs.
  • Lex
    I love the uninstall option because it removes the programs leftovers.
  • Gary L.
    Over the weekend, a friend decided to upgrade his Vista system to Win7 after continuous problems for 2+ months after installing Norton 360. He was running WebRoot AV SpySweeper 2010 w/o any problems. A geek at Best Buy convinced him into thinking he also needed Norton 360 v4.0!!! We all know Norton is the play ground bully. It won’t play well with any other AV, Spyware, or Firewall software!!! He had tried to uninstall Norton 9 times (even calling Norton Tech for assistance) without success. We all know Norton is like the bad relatives that won’t ever leave, unless you grab the pry bar, hammer, and maybe some dynamite!!!
    At a point of total desperation, he was about to do a “clean” install for Win7, but he would have lost important files, docs and pics from Vista. I volunteered my services and that of Revo UnInstaller Pro v2.0 (which I’ve been using about 6 months).
    The first pass with Revo didn’t remove all the tentacles of Norton in the Registry (Norton is like a cancerous rootkit in the Registry!!) On the second pass, I used the “Forced Uninstall” and successfully removed “all” traces of Norton including the dlls and all the Registry keys.
    Rebooted, and once again his Vista computer was operating smoothly. The WebRoot AV-SpySweeper was operating correctly. I then did a migration update to Win7, keeping all his important files, docs and pics from Vista. When finished, I loaded Vipre v4.0 as a second AV and Firewall line of defense (it plays well with WebRoot and has about a third the footprint of Norton). Needless to say, my friend was very happy with the results (he is indebted for many steak dinners)!!!!
    While Revo does create Restore Points and Registry Backup and allow tracking of all changes during an installation, it’s name does include “UnInstaller”….which is the reason I use it…..and “Forced Uninstaller” is the primo feature. It does provide locatons for all folders, sub-folders, dlls, and registry keys if you wish to perform neuro-surgery on the system yourself!!!
    The free version of Revo UnInstaller works very well; it does about 80% of what the Pro version does, but the remaining 20% in the Pro version is what sets it apart from the wannabes!!
    Quite simply, Revo Uninstaller Pro works totally and completely (every time in 27 uses in the last 6 months)!!!!
  • http://community.livejournal.com/randomized_g/ Narisa
    Revo SAVES me sooooo much time in cleaning up things left over by uninstalled programs. Makes me happy that my computer can run nice and fast without hassle. Great program and my best friend!
  • ely
    I really would like a Pro version!
    What I like most about this sw it’s the fact that it also keeps the registry clean…
  • tantruong
    I used free product. IT is well.
  • Lakmal
    hi,thank you very much for this give away TWC…Revo uninstaller is a powerful uninstaller software…i like this uninsatller…it nicely removes all the leftovers of softwares which inbuit uninsatller cannot remove..it has a back up manager too…in addition auto run manager can be used to disable unneccesary start up programms & speed up PC….”office clearner” will remove trash files which have accumulated…WINDOWS tools,also,important..i would like to win a genuine license of revo uninstaller pro…thank you again…
  • Luther
    I especially like the way it ‘deep cleans’ the registry while still giving you some control over the process. A clean registry is one of the keys to a healthy PC. Revo Uninstaller is a must-have program for your PC.
  • Joe
    I had no idea what was left behind using most programs builtin uninstaller until I viewed the Windows registry. Wow. Revo Uninstaller does a much better job. Thanks for letting me know about this program.
  • Garagantur
    Hi guys,
    The built-in uninstallers of most windows applications are crap, they almost ever leave some traces.
    I really like the way how reliable Revouninstaller works, with scanning all the remaining data files that usually stay back when only using built in uninstallers (e.g. preferences&profildata) and on top of that it even keeps the registry solid too!
    It surely supports keeping up a clean system without any needs of manuel deletion of any files or registry entries afterwards some deletion.
    Never understood why third-party software developer create such bad uninstallers in the beginning, but I’m just relieved there is Revouninstaller.
    Sure wouldn’t mind to get a license for a reliable application like this!
    Anyway I will stick too it, even if it’s just the free version.
  • Garagantur
    Hi,
  • Anthony
    I use revo uninstaller when I’m uninstalling a program I like how it takes all the files that windows look past and I know that once it’s gone it’s gone for good…
  • shiva
    thankyou twc for this giveaway, really a great software and really a great giveaway, please do consider me, will be really happy if i can win a license thankyou a lot.
  • kweeny
    Thanks for another great giveaway opportunity. Have been using Revo Uninsaller free version these last few years since its the best at what it does. Like the way it creates restore point and then totally uninstalls a program without leaving out anything. The Pro version can only be much better since it has realtime monitoring during installations.
  • alex19100
    thank’s for this giveaway.
    Ibeen using Revo Unistaller free version,I like the hunter mode,3 level scan for file,and the resore point automatic.
    this programm is very good,I hope to win a pro license.
    thank’s
  • GT
    I’m liking the feature of removing registry keys fully, uninstall trails softwares i’m use + it works only on 64-bit Windows7, but not free.
    Please select me randomly.
    Regards, Mr G.T.
  • Evandro
    Hello friends!
    Revo Uninstaller is a top software for me. I’ve been tested several uninstall programs, and this is the best. I hope that I can win this giveaway too, because the Pro version is probaly better then the already good freeware. Thanks a lot! Regards.
  • Andrea Quinn
    Revo Uninstaller is an all rounder for removing stubborn programmes from a pc. I especially like the feature that looks for registry entries that can be left behind using Add/Remove programmes. A great programme to have on any pc. I use the free version and the pro version would be an added bonus.
  • Oaken
    Revo is simply the best at clearing up the mess which poor uninstallers would leave behind.
    My favourite feature is Hunter Mode, which makes life a whole lot easier when getting shot of experimental software from the desktop.
    Just a shame the free version can’t do the same for shoddy software writers – but if you grant me a Pro license please – perhaps it might do! :-)
  • http://madeinholt.co.uk madeinholt
    Howdy partners,
    I had been using Revo free for sometime until I switched to 64 bit computing. Revo was great because it has loads of cleaning utilities and features all accessable from one neat looking interface. I think it does a bit of uninstalling too ;)
  • Imbert Guy
    Hello,
    For me and I think for the most Revo Unistaller users is this wonderfull program one off the best software ever made in this crazy world, I give it a ten ! ! !
    Regards,
    Guy,
  • joel
    I have been using Revo for a very long time. I’ve been tested several uninstall programs, and this is the best. I especially like the feature that looks for registry entries that can be left behind using Add/Remove. I hope I can win the license.
  • Khubseerat
    Alongside all the other beneficial features this posh software provides, the feature I like the most is that it can remove related left over registry keys. Revo Pro keeps it all clean & smooth. I’d love to be able to use its all features.
  • Grr
    Hi TWC/Optimus,
    Thanks for bringing us this opportunity.
    The features that i liked in the pro version are Forced Uninstall, Realtime Monitor & Hunter Mode. I install & use lot of softwares on my main & only PC and having Revo Pro will clean my system on uninstalling these testing softwares.
    Kindly consider me in the draw.
    Thanks, Grr
  • GENUSE
    I like the removal of registry keys and the removal of files left in program data section.
    It really does its job.
  • kbm24
    thankyou twc for the chance to win a revo uninstaller. really a great product
    the specialities that i adore in revo pro are
    * hunter mode
    This is a special, innovative feature of Revo uninstaller which indeed has two sub modes – Hunter mode and Drag and drop mode. These modes are giving you a flexibility to uninstall applications with one click (stop or delete) by simply dragging and dropping program icons to the Hunter icon or selecting their icon with the mouse cursor, whether it’s on the desktop, quick launch toolbar, in the system tray or the program’s window is open.
    * Real-Time Installation Monitor
    Revo Uninstaller Pro has a feature that allows monitoring of installation of a program and detects system changes during that installation. The process is done in real time – simultaneously!
    This feature is very powerful because by monitoring system changes during the installation, we eliminate all the scanning algorithms when we need to uninstall that program and nevertheless we can still use these algorithms but in another feature called Forced Uninstall.
    Forced Uninstall is very useful and powerful program removal feature that is available in Revo Uninstaller Pro! Even when a program is uninstalled with Revo Uninstaller it could leave some leftovers because of the selected uninstall mode or because there is not enough reliable info about the uninstalled program. The user could tell where the leftover files or folders are, and according to that info Revo Uninstaller Pro could scan Windows Registry and the file system for even more related leftovers. Forced Uninstall gives a lot of power to the user but still keeps the safety of the system! It is very useful when the installation is corrupted and cannot continue further. Forced Uninstall is the best solution when you have to remove partially installed programs, partially uninstalled programs, and programs not listed as installed at all.
    * Multi-Level backup system –
    guarantees that with Revo Uninstaller Pro you can safely uninstall and remove remnants of programs. Revo Uninstaller Pro creates backups of removed registry keys, values, files and folders. Before each uninstall of a program it creates a System Restore Point. For maximum protection and safety It also makes full registry backup that could be used even when Windows cannot start at all! You can use that registry backup even when some other program, virus or something else has damaged the whole system.
    * Print and Export of the installed programs –
    Revo Uninstaller Pro let you to print and/or export all details of your installed programs in few handy file formats. So later if you need to reinstall your software configuration it will be much easier to find and install the right programs that you like and use all the time.
    * Full native 64-bit support –
    Revo Uninstaller Pro takes all advantages, power and speed of 64 bit Windows operating systems including the latest Windows 7 64-bit.
    Revo Uninstaller Pro scans for leftovers with even more advanced algorithms that are so precise, fast and very effective in search for leftovers of Windows Services, Drivers, File associations, Shell Extensions, COM components, Windows Installer components, program settings and more!
    so please put me in the draw and it would be great to win here
    thankyou
  • Rui Costa
    The feature I love the most is “Forced Install”. It’s a really useful feature as sometimes I don’t/can’t use Revo Uninstaller to uninstall a piece of software so I can always remove leftovers and keep my system clean.
  • Termal
    I really like the deep and radical cleaning that Revo does. I have never seen so far so good program.
    I have doubts in the past about using it, but now i can’t imagine my PC with this excellent program.
  • http://www.twitter.com/MrMBerman MrMBerman
    I like the ability to scan the registry for left over unwanted entries that normal uninstalls leave behind.
  • http://comp32.webs.com Suyash Swaroop
    I liked this very very much because it’s not only an uninstaller but removes all the traces of the program after uninstalling.
  • vishnudhasan
    thankyou TWC for running this fabulous giveaway.Thankyou revo group for sponsoring them.
    i am user of the revo free version for the past 2 years, a chance to win the pro would be just great and extraordinary so i pray to you to count me in the giveaway.
    now what aspect of the pro version do i admire.
    each and every feature of revo is excellent , the makers have done a great job to give us such a good product.
    the hunter mode is just an example of its efficiency.
    the ability to backup in multilevel is too good
    64 bit support is an added plus.
    real time installation is an must for all computers.
    forced uninstall is a real Delicious topping for this beauty.
    do you know revo is one of the best teacher available on our computer, yes revo teaches us about various program with its unique print and export feature.
    do you want more , yes revo gives us more
    it provides us with 8 extra handy and powerful tools to clean up your system namely – AutoRun Manager, Windows Tools Manager, Junk Files Cleaner, Browsers History Cleaner, Office History Cleaner, Windows History Cleaner, Unrecoverable Delete Tool, and Evidence Remover.
    i know , i will keep on praising it the whole day so let me stop and make my request to you
    yes please consider this poor fellow , i am really interested in winning this pro version of revo. so put my name is the lucky pot and i pray to the mother of luck to shower her kindness upon me and let my name be one along with the other nine winners so that we all shout cheers together as one happy lot.
    thankyou twc and revo
  • FishFearMe
    I use the free version of Revo Uninstaller and I love it. The thing I like best is that Revo gets rid of all the left-behind files,etc that standard uninstallers don’t remove.
  • llkkzxcv
    Revo Uninstaller Pro is a great application. The feature I like the most is removing programs and registry entries related to a program which couldn’t uninstall properly. Hope i can get one of these licenses. Thanks in advance.
    Source: http://www.thewindowsclub.com/weekened-giveaway-10-licenses-of-revo-uninstaller-pro#ixzz0oQ5bvRI1
  • j.b.
    My favorite feature is that it gets rid of the leftover junk when it uninstalls.
  • Will
    My favourite feature is the forced unistall utility allows you to get rid of troublesome programs
  • Maxwell
    The feature I like the most was the program did remove software and all it trace in between 90%~100%.
    We consider it as a complete uninstaller.
  • relly
    well,if the free version is really very good, and i’ve been using this, for such a long time, what i like about the pro version is that it is more comprehensive, complete, as describe,and i know it will really be very useful,i hope i’ll win one license, thanks alot…….
  • frid
    the real time installation monitor is what i like in the pro version of revo, thankyou twc for this giveaway, so please count me.
  • Carlos
    I like most that, when uninstalling a program, Revo allows me to remove any registry entry left behind by the program uninstaller.
  • http://www.thewindowsclub.com/ Windows Club
    4 days up! Closing thread. Will declare results in a day or two.
