If you are one who frequently installs or uninstalls applications or one who loves to play with the Windows Registry, then this is one freeware portable app you’d want to have around!
Single Click Restore Point Creator lets you create a restore point in a click!
Rather than the 4-5 clicks you have to undertake to navigate through the Control Panel, with this app, it can be effected in a single click.
Simply place the .exe file in the Programs Folder and create its shortcut in the Start Menu or the Task Bar, for easy access.
Works fine on Windows 7 too ! A sure shot time-saver!
Download: Single Click Restore Point Creator.
If you have liked this post, you might want to check out some more, on topics like Portable Apps, System Restore.
