Check Read and Write Speed of Hard Drive, CD-ROM, Network Servers
Read speed is the rate at which data is transferred from a disc to a computer. Write speed is the rate at which data can be written to a disc. The higher your speeds the faster is your data transfers.
parkdale read write speed Check Read and Write Speed of Hard Drive, CD ROM, Network Servers
Parkdale is free tool to measure and test Read and Write Speed of Hard Drive, CD-ROM, Network Servers, etc. Simply select the drive and click on Start to run the test. The transfer rate is displayed in KB or MB per second. You can also adjust the blocksize used to access the disk.
The program has two different modes:
  • BlockAccess – The test data is read from/written onto the disk directly without using the filesystem.
  • FileAccess – The test data is read from/written into a normal file using the filesystem.
Several comnmandline options are also available. All options are shown if the program is started with ‘-?’.
Home Page.
Know of any more such freeware to measure read-write speeds? Please do share in the comments.
If you have liked this post, you might want to check out some more, on topics like , .
About AnandK@TWC
Anand aka HappyAndyK is an end-user Windows enthusiast, a Microsoft MVP in Windows Desktop Experience since 2007, and the Admin of TheWindowsClub.com, TheGeeksClub.com & WinVistaClub.com. Creating a System Restore Point before trying out a new software or a tweak is always recommended.
Ads
Random Posts
  • http://techgopal.com TechGopal
    really nice tool…….
    i will try this……..
