CAM software will monitor your PC and keep it running optimally
As a gaming enthusiast, you’re always looking for ways to fine-tune the performance of your PC to get maximum out of it. As such, you continuously build, test and monitor your device. Unknowingly, this becomes a never-ending exercise. Not anymore! Check CAM, a free PC monitoring tool by NZXT. CAM is an all-encompassing tool for your Windows PC to keep track of key components’ temperatures, overclock GPUs, and display FPS in game. It monitors and records your frequency and FPS data.
CAM is a free PC monitoring tool
CAM is a free Windows software that you can use for FPS monitoring and PC monitoring in general. The tool is different from its earlier iterations in a way that the interface has been redesigned to streamline the user experience. Also, few tweaks have been made to the backend so that most users consume significantly less amount of CPU, just 1% and 120MB of RAM!
The main dashboard boasts a new, clean Basic view that shows you all the most important stats upfront with a clean and easy to read layout. You can find Build, Games and Devices tab alongside the Dashboard.
While being in the ‘Basic View’, you can switch to the guest mode to avoid signing up, but by doing so, you will be prohibited from access the historical data stored in CAM cloud. If you do not mind, proceed further!
Initially, you will be greeted with a screen displaying your Desktop specs as seen in the screenshot below.
Press ‘Let’s dive in’ to switch to Dashboard of the program. Here, you can access all options to help you monitor your PC’s vitals quickly and easily. For instance, you can see your Desktop’s FPS stats for the last game session. All you need to do is enable CAM FPS overlay. For this, click on ‘Settings’ icon, choose ‘FPS overlay’ and hit ‘Enable CAM overlay’.
Then, choose your presets like FPS, Resolution, Memory, etc.
Likewise, you can choose the desired size of the ‘Fonts’. There are four font sizes offered by default,
  1. Small
  2. Medium
  3. Large
  4. X-large
A good feature about this program is you can scale font with resolution. What does this mean? Even if you change the resolution, the font size remains the same. i.e., it does not change even when the resolution of the screen is altered.
Switching to ‘Advanced’ Tab (just adjacent to ‘Basic view’) lets you check vital statistics of your PC in a glimpse. You can check usage for the following,
  1. CPU
  2. Motherboard
  3. RAM
  4. Storage Drive
The ‘Games’ Tab lets a user save his game performance to the cloud. This is useful since it allows the user to view and compare performances across their most and recently played games. CAM can capture and save game performance data to the cloud to provide you insight into performance across your most played games. To enable all this CAM requires being synced to an online account. Therefore, you need to login first.
To get the optimal overlay experience, you can install DirectX End-User Runtime
The latest version adds new features. An example – there’s ‘Detect Devices’ button added under ‘Devices Pages’ section for users having trouble not being able to use their CAM powered devices. To use this feature,
Go to Devices Tab then click on Detect Devices, wait for loading bar to finish. The results will be displayed, instantly.
In all, CAM by NZXT is a useful tool which shows far more detail than can be covered here. Download Cam from its homepage.
Posted by on , in Category Windows with Tags
The author Hemant Saxena is a post-graduate in bio-technology and has an immense interest in following Windows, Office and other technology developments. Quiet by nature, he is an avid Lacrosse player. Creating a System Restore Point first before installing a new software, and being careful about any third-party offers while installing freeware is recommended.
