List of 5 best Power Supply Units for your computer
Power Supply Units or PSUs are an essential part of your setup, to avoid any power spikes. But with the advent of numerous companies bringing out a variety of options into the market, it is becoming all the more difficult to choose one for your home. A good PSU has optimum protection features to be able to save your PC components, including the power socket itself, should something go wrong.
Before you begin, you might want to first check how much Power your Computer needs.
Best Power Supply Units
Here we look at the top 5 best brands for Power Supply Units or PSUs that you can buy for your computer. Let’s check them out.
1. EVGA 500 W1
evga-w1
The EVGA 500 W1 is one of the bestselling PSUs out there in the market. With an affordable price tag and a capacity of 500W, enough to run a medium-built computer, the EVGA 500 is a no-brainer if you are looking to invest in a simple, no-frills power supply. It has additional features like Quiet and Intelligent Auto Fan for near-silent operation and a good 3-year warranty. Price: $36.
2. Sentey XPP725
If you are looking for something high-end, the Sentey XPP725 is the one you should be looking at. With a capacity of 725W, this PSU means serious business and can run anything from your gaming PC to your powerful editing machine. The PSU also includes a single dedicated +12V rail; that simplifies component installation by having all the power on a single line, avoiding having to manually balance the component load on multiple rails. Price: $45.
3. Corsair CX600
corsair-cx600
This trustable 600W PSU from Corsair is one of the best that money can buy. The CX series starts at 400 Watt capacity all the way up to 850 Watts, depending on your requirement. But, the CX600 is the most popular because of its sheer compatibility with most Intel processors in the market. It also has a quiet 120mm fan that delivers great airflow at a low noise level by varying fan speed in response to temperature. The CX600 also has a 0.99 Active Power Factor Correction that provides clean and reliable power. Price: $69.
4. EVGA SuperNova 750
evga-supernova
Another high-end PSU you can buy is the SuperNova 750 from EVGA. It’s priced quite steeply at around $120, but it has a decent 10-year warranty to future-proof your computer from any irregular power performance. This power supply is sleek and stylish, and packs in some Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection). Price: $70.
5. Corsair RMx650x
corsair-650
Another trustable range from Corsair is the RM series. The 650W model is our pick as it can handle most of your processes and then a little more. It has the 80 Plus certification and has some premium internal components that ensure solid power delivery and long term reliability. It also has a special Zero RPM Fan Mode and provides for virtually silent operation at low and medium loads. Price: $113.
Your suggestions are most welcome.
Posted by on , in Category General with Tags
A constant learner of gadgets, Ankit has been writing about technology and the internet, in general, for the past three years, and has written for several well-known media outlets.
